manxdoc
Dec 19, 2020Guide
Change region
Hi. I bought an Orbi RBK53 from the US. It seems to work well but the region the Router and satellittes is set as "North America" and cannot be changed. Does this affect the performance of the RBK5...
- Dec 20, 2020
SOLVED!
I managed to resolve this thanks to FURRYe38 and ekhalil
1) Enable telnet on router and satellite by enabling telnet on web management
e.g. 192.168.1.x/debug.htm
2. login
3.
REGION read:
root@RBR50:/# artmtd -r region
The region number is: 0x0001
REGION: NA (North America for me)
4.
REGION write:
root@RBR50:/# artmtd -w region "region name"
For instance : artmtd -w region WW (worldwide)
5.
At this point the Region Selection in the Advanced Wireless Settings will not be greyed out any longer and you're able to chose any region, in my case Europe!
CrimpOn
Dec 19, 2020Guru - Experienced User
manxdoc wrote:Hi. I bought an Orbi RBK53 from the US.
Does this affect the performance of the RBK53?
How can I change the region? I read instructions to use Telnet to change the region but I keep getting error messages.
Are these the directions you followed to change the Region code?
https://community.netgear.com/t5/Orbi/Orbi-RKB53-global-differences/m-p/1736104#M59059
The main effect of Region code is which WiFi channels are available and the radio power levels.
Each region has different regulations.
In practical terms, not much effect.
- manxdocDec 20, 2020Guide
Thank you CrimpOn. I will have a look. It seems promising...
SHame the link above it doesn't work any longer...
SOLVED!
2. login
3.
REGION read:
4.
REGION write:
5.
- FURRYe38Dec 20, 2020Guru - Experienced User
Enjoy. :smileywink:
