srdavis872
Feb 17, 2021Apprentice
Change wifi setting for router but not satellite?
I had a thread previously under: https://community.netgear.com/t5/Orbi/Orbi-RBK50-Speeds-Drop/m-p/1955406 Still experiencing issues and after rearranging my set up, I learned something new. When ...
CrimpOn
Feb 17, 2021Guru - Experienced User
srdavis872 wrote:Is there any settings I can adjust for the single main router, or can I turn it's wifi off entirely and just use the satellites?
No. All settings apply to the entire system. Router and satellites all use the same WiFi channels (2.4G and 5G) and all follow the same "Transmit Power" setting.
