fade6
Jun 18, 2020Aspirant
Changing Backhaul Channel (to Help with Wireless Speakers)
Hello all. I wanted to update an older post regarding using telnet to change the hidden channel backhaul. First, a little background: My router/sats = RB40/RBS40 Orbi is used as a router (not AP...
ZeusyZeus
Hey fade6 thank you I actually tried that from the telnet post before yours and I didn’t see any change. Really appreciate you taking the time to help the others having these frustrating issues! Any other thoughts on how I can get it to not interfere? Are you no longer having WiFi interference? Was was your issue before speaker cracking or poor WiFi connectivity. I have the connectivity issue.
- fade6Jun 18, 2020Aspirant
Yeah, same system you have HW-Q90R... popping noises... drops from the rear set.
Try what I posted one last time. My orbi backhaul has been on Channel 108 nice and steady for a week now. Speakers are working perfectly. As other posted - channel 108 is one of the radar channels, so if you live in an area that uses radar, the Orbi will kick it back to where it was... so cross your fingers. I hope it works for you!
