fade6
Jun 18, 2020Aspirant
Changing Backhaul Channel (to Help with Wireless Speakers)
Hello all. I wanted to update an older post regarding using telnet to change the hidden channel backhaul. First, a little background: My router/sats = RB40/RBS40 Orbi is used as a router (not AP...
ZeusyZeus
Ok so the command you listed shows my front haul channel of 48 (same as yours). You’re saying change this to 108? I’ll try it.
