franktribe
Apr 27, 2018Apprentice
Changing Channels Disconnects Satellites
Have you guys seen that when you change the channel on the 2.4Ghz Wifi network, it disconnects the Satellites and they don't connect back. I was able to change the 5Ghz network channel and the satell...
franktribe
Interesting, I changed my 2.5Ghz back to Auto and the satellites reconnected. Bug? Can't set the 2.4Ghz channel when the satellites are connected via the Ethernet backhaul?
