franktribe
Apr 27, 2018Apprentice
Changing Channels Disconnects Satellites
Have you guys seen that when you change the channel on the 2.4Ghz Wifi network, it disconnects the Satellites and they don't connect back. I was able to change the 5Ghz network channel and the satell...
Apr 28, 2018Guru - Experienced User
How long are you giving the system after you apply the channel change for the system to come back to ready. Should take about 2 minutes max I think.
What is the distance between the router and satealllites? too close and the system will not work well. 30feet to begin with in between. The router alone can cover up to 30-40feet depending. You may only need 1 extra satellite with the router.
What FW version are you using?
There are no supported channel configurations on the satellites.
