mathes-3_maccom
Mar 15, 2019Initiate
Changing device name
For security reasons, I'd like to change the router network name.
If anyone from Netgear is listening, I've found it incredibly difficult to find information, much less complete the task. Inve...
Mar 15, 2019Guru - Experienced User
What would you like to change? WiFi SSID name or a connected device name?
Changing names can be done using a PC and web browser connected to the routers web page at orbilogin.com
If anyone from Netgear is listening, I've found it incredibly difficult to find information, much less complete the task. Investing in the expense of a new system is becoming more appealing.
This is a common security recommendation. It shouldn't be that hard.
- mathes-3_maccomMar 15, 2019Initiate
Dear Sensei Furry,
Success! Thank you so much!
I changed it three times for the fun of it!
Rick Mathes
- FURRYe38Mar 18, 2019Guru - Experienced User
Glad that worked. Enjoy. :smileywink:
Dear Sensei Furry,
Rick Mathes
