pablohoney
Apr 11, 2020Luminary
Changing email address associated with Orbi RBK50
PM sent to Blanca with my details. Please amend the email address associated with my router to my new email address please.
- Apr 12, 2020Ignore as I was using a different email address initially. All sorted now!
michaelkenward
Apr 11, 2020Guru - Experienced User
pablohoney wrote:
...my old email address is linked to the serial no. of my Orbi.
How?
MyNetgear is where my serial numbers are tied to the system.
Change the email address there and the serial numbers should follow.
Maybe you haven't signed up to MyNetgear, and can't see your devices registered.
That is why I asked how your devices were linked to a particular email address.
Help us out here. Explain what is going on without making any assumptions about what has to happen.
pablohoney
Apr 12, 2020Luminary
My existing account is not found and I cannot log in under it for some reason. Hence me seeking help from Netgear directly.
- pablohoneyApr 12, 2020LuminaryIgnore as I was using a different email address initially. All sorted now!
- michaelkenwardApr 12, 2020Guru - Experienced User
pablohoney wrote:
Ignore as I was using a different email address initially. All sorted now!I bet I can beat you for the number if email addresses I have set up and forgotten.
Good to know that you did it without divine (Moderator) intervention. Clearly they don't make it easy for us punters to do this.
Does that mean that you managed it through MyNetgear?
You could help others by clicking the Accept as Solution button for whichever message got you across the finishing line.
