Candacewcarlson
Dec 23, 2021Aspirant
Changing from 5 to 2.4 on a Netgear Orbi rb50 from IOS
Hi I hae only does this once before and I can't remember how to do it. I have a Weather station that needs to connect on setup to 2.4. I have tried bringing down the satellites and moving close...
Dec 23, 2021Guru - Experienced User
Turn OFF the RBS. Then change the power output of the 5Ghz radio to 25%. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was. Under Advanced Tab/Advanced Settings/Wireless Settings
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
