safejunk
Apr 12, 2020Star
Changing Guest Lan IP subnet
So I saw this solution for a Orbi RBR850 and I thought someone with a RBR50 was able to do this as well, but I have a RBR40 and a RBR20 and while it takes the commands and keeps them after I reboot, ...
- Apr 12, 2020
safejunk wrote:So I saw this solution for a Orbi RBR850 and I thought someone with a RBR50 was able to do this as well, but I have a RBR40 and a RBR20 and while it takes the commands and keeps them after I reboot, connecting my Laptop to main net work and iPhone to Guest Network simply does not give me the differet pool IP I expected..
I seem to remember this was one of the "significant differences" between the WiFi5 Orbi and the new WiFi6 Orbi. What a lot of people thought should be "obvious" (i.e. putting Guest devices into a separate IP subnet) was not part of the original Orbi firmware design.
I think you are destined to be unhappy until (and if) Netgear changes the Orbi firmware.
CrimpOn
Apr 12, 2020Guru - Experienced User
