TV_Actor's avatar
TV_Actor
Changing ISP - Will my existing Orbi RBK22 system still work?
I'm moving from L.A. to Colorado in a few months.  Currently, my internet is supplied by Spectrum over a high-speed cable.  My new internet provider will be a satellite ISP.  I'm NOT the most tech-sa...
  • ekhalil's avatar
    Feb 12, 2019
    Since you’re using the default SSID I assume that your Orbi is in Router Mode.
    Please ask your new ISP to provide you with a “plain” modem without a  built-in router.
    You should then be able to just plug in Orbi to the new modem and then you will be good to go.
    You will keep all your existing configuration: wifi network name, password, IP addresses,.... etc.
    Good luck!
