rapshank1882
Jun 15, 2021Tutor
Changing ISP from Virgin to BT FTTP
Hi - This is my first post, so please go easy :) I currently have Virgin Media (350 down/30 up) with Orbi RBR850 with one satelite running in router mode - works like a dream. My Virgin SH3 conn...
- Jul 14, 2021
Bingo! bthomehub@btbroadband.com is the required login for for PPPoE (blank password) and all working like a charm :)
Thanks, Furry
rapshank1882
Jul 14, 2021Tutor
Hi Guys
Install day has come and the new FTTP is installed. However, plugging the ethernet fron ONT to Orbi isn'y working. No IP is being assigned and the Orbi flashes white and then solid purple. I have tried switching off Orbi and ONT for 5 minutes a couple of times but not luck.
Do I need to reset the Orbi and carry out a new install or is there any authentication I am missing?
There are a few other posts advising it worked first time direct from ONT to Orbi, some had to use username and password/blank password PPPOE etc etc..
Thanks
Chris
Jul 14, 2021Guru - Experienced User
Contact your ISP to see if PPPoE on the Orbi is required or not...
- rapshank1882Jul 14, 2021Tutor
Thanks, Furry
- FURRYe38Jul 14, 2021Guru - Experienced User
Awesome.
Please mark your thread as solved so others will know.
Enjoy.
