rapshank1882
Jun 15, 2021Tutor
Changing ISP from Virgin to BT FTTP
Hi - This is my first post, so please go easy :) I currently have Virgin Media (350 down/30 up) with Orbi RBR850 with one satelite running in router mode - works like a dream. My Virgin SH3 conn...
- Jul 14, 2021
Bingo! bthomehub@btbroadband.com is the required login for for PPPoE (blank password) and all working like a charm :)
Thanks, Furry
rapshank1882
Jul 14, 2021Tutor
Thanks, Furry
Jul 14, 2021Guru - Experienced User
Awesome.
Please mark your thread as solved so others will know.
Enjoy.
