Star-rider's avatar
Star-rider
Changing older orbi into access point for latest 960 router.
Hi,   My current config CM2000| Orbi RB50 | 3 satelites. If I but one of the latest Orbi mesh routers can I change my config to be like the following:   CM2000| Orbi 960 | access point Orbi RB50 ...
  • plemans's avatar
    Nov 04, 2022
    Yes you can connect the older orbi setup to the newer AX  with the older in access point mode. The AC satellites will only connect to the AC router.
