rb1511
Jul 29, 2020Aspirant
Channel conflict between ORBI CBK43 and AT&T U-Verse on 5 Mhz
I just bought and installed the ORBI CBK43 - Mesh system with a base and 2 satillities (RBS40, 2 - RBS20). However, they system is interferring with my picture on my AT&T U-Verse receiver/TV. My A...
- Jul 29, 2020
Start here on the Orbi base -> https://community.netgear.com/t5/Orbi/Wireless-Backhaul-Channel/m-p/1816843/highlight/true#M74043
schumaku
Jul 29, 2020Guru - Experienced User
rb1511
Jul 30, 2020Aspirant
I responded too soon. It really didn't solve my problem. I used the config get/config set and config commit commands. The config get shows that my config set worked and the new channel is 108. I also tried and used channel 149. However, in both cases even though it says my 2nd hidden channel has changed, my ORBI RBR40 and RBS20's are still using channel 157. Do these devices use a different hidden channel I need to change beside or instead of 2nd_Hidden_Channel?
- rb1511Aug 01, 2020Aspirant
Finally solved my problem channeling the backhaul channel. Turned out I had to change wla_hidden_channel and not wla_2nd_hidden_channel.
