csmba15
Jan 22, 2021Tutor
cheapest extension for RBR50
I have RBR50 with 2 units, works well. but my kids room is far and gets weak signal. what ist he best cheap option to extend my setup? I figured the plugin RBW30 but 1/ it will work, right? 2/ w...
alokeprasad
Jan 23, 2021Mentor
In the interest of full disclosure, the RBS40V ($100) is an AC2200 device and will be marginally slower than the $240 RBS50 (an AC3000 device). The difference won't be noticable for almost all usage conditions.
The bang for the buck definitely favors RBS40V.
csmba15
Jan 23, 2021Tutor
Thanks, feels weired to get when it seems that RBW30 should be the cheaper/better option for what I need.. it feels that you take away the speaker and it should be cheaper no?
sad netgear is pricing the simple satelight so high... I can't find the RBW30 anywhere so I guess I should just get the RBS40V...
