The_Principal
Apr 13, 2020Follower
Chromcast connectivity issues
Can someone please help or recommend something as an alternative??? Just installed my Orbi. I use my chrome cast for my TV...it’s not connecting...can this be fixed????
Apr 13, 2020Guru - Experienced User
Is this a new first installation of Chromecast or have you had this device for a while?
Are you using the same SSID name and PW on Orbi from your prior router configuration?
