RedBatman89
Sep 12, 2019Guide
Chrome 77 breaks orbi login page.
Ok so I had updated to Google Chrome 77 on my laptop last night, well this morning when I went to my orbi router page (192.168.1.1) For a just a secound it gives me the prompt to enter my password an...
Blanca_O
Sep 12, 2019NETGEAR Employee Retired
Hi, All,
We have tried to replicate the issue but was not able to reproduce it. Orbi is on the latest firmware 2.3.5.30 and Chrome version 77.0.3865.75 (Official Build) (64-bit). We were able to access it using the IP address and orbilogin.com.
May we request for the following information:
- Exact Chrome version / string
- Firmware version
- Is it the same behavior if it is in incognito mode?
- Do you access it using IP address or orbilogin.com/net?
- Did you try to clear cache?
Blanca
Community Team
CrimpOn
Sep 12, 2019Guru - Experienced User
I fear this one will never be solved. I, also, got the "401 Unauthorized enter serial number" screen when I tried Chrome Version 77.0.3865.75 (Official Build) (64-bit) using the Orbi IP address. Seeing your recent message, I just tried again. This time, Chrome made the usual complaint about the connection not being "secure" (i.e. http rather than https), but accepted my login and "it works." Now that Chrome worked once, it continues to work.
- FURRYe38Sep 12, 2019Guru - Experienced User
One user on a different forum mentioned that he restarted his PC and it seemed to resolve the issue for him and Chrome accessing the log in page.
Any one restarted or re-booted there PC?
