rohangupte
Aug 28, 2019Aspirant
Chrome devices not connecting to Orbi wireless after FW update
I have a RBR50 with a satellite. Last week, I downloaded a FW update. RBR50 is now running on version: V2.3.5.30 SInce then all the Chrome/Android devices have stopped connecting to Orbi. I can ...
rohangupte
Aug 29, 2019Aspirant
My Setup:
Cable ( 150Mbps/10Mbps) > Cable Modem (Arris TM3402) > RBR50 (Router Mode) > RBS50
Performed 2 Factory reset and setup since FW update. Connectivity problems continue with the Chrome/Android devices.
3500 sq ft. RBR50 is on lower level, Satellite is on upper level ~20-30 ft away. Again there were no issues with connectivity or coverage prior to the FW update.
Auto Channels. tried setting manual channels for 2.4GHz - no improvement.
4-5 Neighboring Wi-Fi networks
Beamforming is enabled.
Haven not tried this:
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only.
All devices were connecting and functioning perfectly before the FW update.
Aug 29, 2019Guru - Experienced User
You can manually download the last working FW version for the RBR and revert back. Use a wired PC and web browser for this process.
- rohangupteAug 29, 2019Aspirant
Thank You.
- FURRYe38Aug 30, 2019Guru - Experienced User
- Retired_MemberAug 30, 2019
FURRYe38 wrote:You can manually download the last working FW version for the RBR and revert back. Use a wired PC and web browser for this process.
I'm glad you liked my suggestion. You're welcome!
