BostonTaylor
Apr 14, 2021Initiate
Chromebook consistently slower than other devices on Orbi
I have an Orbi mesh network with 2 satelites. I did a room by room, device by device comparison using speedtest.net. Our chromebook (x360 bought last year) doesn't exceed 40mbps where apple devices c...
- Apr 14, 2021
Be sure to make a backup configuration to file for safe keeping on the RBR. Saves time of a reset is needed. Please mark your thread as solved so others will know.
BostonTaylor wrote:
So I solved it (accidentally)... the router needed updates, something I don’t think was visible via the app but was via the web login. Chromebook is cruising now!
vajim
Apr 14, 2021Master
BostonTaylor wrote:I have an Orbi mesh network with 2 satelites. I did a room by room, device by device comparison using speedtest.net. Our chromebook (x360 bought last year) doesn't exceed 40mbps where apple devices can reach 200mbps. I did notice the Chromebook is commonly on the 2.4ghz, but I don't know if that matters. Is there anything you could recommend to help my Chromebook take fuller advantage of my network?
reset everything by restarting modem, router and device.
- BostonTaylorApr 14, 2021InitiateSo I solved it (accidentally)... the router needed updates, something I don’t think was visible via the app but was via the web login. Chromebook is cruising now!
- vajimApr 14, 2021Master
BostonTaylor wrote:
So I solved it (accidentally)... the router needed updates, something I don’t think was visible via the app but was via the web login. Chromebook is cruising now!Nice work
- FURRYe38Apr 14, 2021Guru - Experienced User
BostonTaylor wrote:
So I solved it (accidentally)... the router needed updates, something I don’t think was visible via the app but was via the web login. Chromebook is cruising now!- vajimApr 14, 2021Master
FURRYe38 wrote:Be sure to make a backup configuration to file for safe keeping on the RBR. Saves time of a reset is needed. Please mark your thread as solved so others will know.
BostonTaylor wrote:
So I solved it (accidentally)... the router needed updates, something I don’t think was visible via the app but was via the web login. Chromebook is cruising now!he already did
