smalldog
Feb 12, 2020Tutor
chromebook orbi DNS Server
Just purchased Orbi mesh router and now lenovo chromebook shows connection to wifi but when attempting to load webpages responds there is no intent connection. Diagnostic reports - No function DNS ...
- Apr 05, 2020
So.... if that happens to you, all you have to do is reset everything by restarting modem, router and device.
Thanks to all who offered suggestions.
sd
Feb 12, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? IF so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Be sure your device is set for automatic networking and IP addressing.
Have the device forget the wifi profile, then reconnect.
- smalldogFeb 14, 2020Tutor
So.. I understand a fraction of what you shared.
I can tell you that the router is sperate from the modem.
The router is RBR10. Wierd thing is that I can use the network at my office...
frimware - v2.3.5.36
- Krb78Mar 31, 2020AspirantI am also getting issues with my kids chromebooks from school not operating properly when connected to the orbi mesh. I’ve had to disconnect it to get them working without errors- same with the smart TVs - 401 and 404 errors all over the place. Turn off the mesh, and it works perfectly (but then we are living w slow speeds) 🤦🏻♀️
- FURRYe38Apr 02, 2020Guru - Experienced User
What model Orbi do you have?
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?Is Circle enabled on the RBR?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
