smalldog
Feb 12, 2020Tutor
chromebook orbi DNS Server
Just purchased Orbi mesh router and now lenovo chromebook shows connection to wifi but when attempting to load webpages responds there is no intent connection. Diagnostic reports - No function DNS ...
- Apr 05, 2020
So.... if that happens to you, all you have to do is reset everything by restarting modem, router and device.
Thanks to all who offered suggestions.
sd
Feb 12, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? IF so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Be sure your device is set for automatic networking and IP addressing.
Have the device forget the wifi profile, then reconnect.
smalldog
Feb 14, 2020Tutor
So.. I understand a fraction of what you shared.
I can tell you that the router is sperate from the modem.
The router is RBR10. Wierd thing is that I can use the network at my office...
frimware - v2.3.5.36
