smalldog
Feb 12, 2020Tutor
chromebook orbi DNS Server
Just purchased Orbi mesh router and now lenovo chromebook shows connection to wifi but when attempting to load webpages responds there is no intent connection. Diagnostic reports - No function DNS ...
- Apr 05, 2020
So.... if that happens to you, all you have to do is reset everything by restarting modem, router and device.
Thanks to all who offered suggestions.
sd
Krb78
Mar 31, 2020Aspirant
I am also getting issues with my kids chromebooks from school not operating properly when connected to the orbi mesh. I’ve had to disconnect it to get them working without errors- same with the smart TVs - 401 and 404 errors all over the place. Turn off the mesh, and it works perfectly (but then we are living w slow speeds) 🤦🏻♀️
Apr 02, 2020Guru - Experienced User
What model Orbi do you have?
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Is Circle enabled on the RBR?
