smalldog
Feb 12, 2020Tutor
chromebook orbi DNS Server
Just purchased Orbi mesh router and now lenovo chromebook shows connection to wifi but when attempting to load webpages responds there is no intent connection. Diagnostic reports - No function DNS ...
- Apr 05, 2020
So.... if that happens to you, all you have to do is reset everything by restarting modem, router and device.
Thanks to all who offered suggestions.
sd
smalldog
Apr 05, 2020Tutor
sd
Apr 05, 2020Guru - Experienced User
Glad you got it working and thanks for posting the fix.
Please mark your post as solved so others will know.
Enjoy. :smileywink:
smalldog wrote:So.... if that happens to you, all you have to do is reset everything by restarting modem, router and device.
sd
