thelovelacefam
Jul 04, 2020Aspirant
Chromebook won't connect to RBR40 since June 2020
I have an RBR40 Firmware Version V2.5.1.16 It works awesome but in June my Chromebook stopped connecting to it. So I bought another Chromebook thinking this one is dead, the new one doesn't con...
- Jul 05, 2020
Thanks, I figured it out. There was a patch fix on my satellite that was needed. It didn't show up until I did a manual update. I appreciate the support!
CrimpOn
Jul 04, 2020Guru - Experienced User
thelovelacefam wrote:It works awesome but in June my Chromebook stopped connecting to it.
So I bought another Chromebook thinking this one is dead, the new one doesn't connect to it either.
However, I can connect the Chromebook to networks at Starbucks or even hot spot from my iPhone.
Can you describe the situation in more detail:
- Are there other devices that connect to the Orbi?
- The Orbi WiFi name (SSID) appears in the Chromebook list of available WiFi networks?
- What is the error message when you attempt to connect?
