thelovelacefam
Jul 04, 2020Aspirant
Chromebook won't connect to RBR40 since June 2020
I have an RBR40 Firmware Version V2.5.1.16 It works awesome but in June my Chromebook stopped connecting to it. So I bought another Chromebook thinking this one is dead, the new one doesn't con...
- Jul 05, 2020
Thanks, I figured it out. There was a patch fix on my satellite that was needed. It didn't show up until I did a manual update. I appreciate the support!
thelovelacefam
Jul 05, 2020Aspirant
Jul 05, 2020Guru - Experienced User
Glad you got it working. Enjoy. :smileywink:
