Stuntman
Sep 12, 2018Follower
Chromebooks no longer connecting
Just recently my Chromebooks have stopped connecting to my Orbi wireless. They connect to neighboring hotspots, and to my phone's hotspot... but won't connect to the Orbi. All other devices in the h...
Sep 13, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What wifi security mode are you using? Try setting WPA and TPIK, then try WPA2 and AES only.
Was there a update to the Chromebook recently?
I presume other devices connect ok to the Orbi wifi?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
