OrbiMan
Apr 16, 2017Luminary
Chromecast and plex server with Orbi. Multicast IGMP proxy?
Hello guys I am happy with my Orbi, however since install I noticed a little quirk with my chromecast and plex. Sometime my android phone would not be able to connect to chromecast and sometime not ...
- Oct 15, 2017As for me it seems to be a problem of too much signal. I cluster the Orbi router and satellite too close to each other, since I spread them out more to the edges of my house the problem went away.
madbrain
Oct 13, 2017Luminary
I have 15 Chromecast Audio and 1 Chromecast Ultra. They kept disappearing from the network on my phone also.
I switched off the Wifi, bought an ethernet interface for each of the CCA, and used AV1200 powerline adapters. Now all is well.
Unfortunately, the Chromecasts just don't play well with wifi mesh. I even tried a Velop on sunday - same exact issue. It's much more problematic when you have a bunch of Chromecast audio in a group and suddenly a few disappear. That means you can no longer control the volume or stop casting to those devices (but they keep streaming!).
https://community.netgear.com/t5/Orbi/Chromecast-Audio-and-AP-Isolation-problem/td-p/1389027
I'm using Wemo switches to turn the amps on/off for all 15 zones, and having problems with that too - they keep randomly dropping off the Orbi network, just like the Chromecast. They do come back eventually. But it's very annoying when you want to turn things on or off and you can't because your phone can no longer see the "smart" plug. Wish there were smart plugs with ethernet instead, but I could not find any.
