Mustyging
Apr 16, 2020Tutor
Chromecast cannot connect to Orbi RBK 13
I bought an Orbi RBK13 (RBR10 + 2xRBS10) and I have gotten all of my devices to connect except for my two V2 Chromecasts. I tried unplugging the satellites thinking that there maybe an issue of them ...
- Apr 16, 2020
WPA and TKIP should work with it.I tried with Daisy chain enabled and disabled and it did not work. Interestly I tried to enable guest access and log into the guest network with the same securty and password (I set the guest network up the same as the normal network) and it connected fine and I can cast from other devices. No idea why it works but its working now. Thanks for your help FURRYe38 !
Mustyging
Apr 16, 2020Tutor
Apr 16, 2020Guru - Experienced User
Wow, thats crazy huh?
What happens if you disable Guest network? Just curious if it will connect to the main wifi after this.
Glad you got it working. Odd process to get those working.
