Flausfsu
Dec 12, 2017Tutor
Chromecast not connecting to 5ghz band
I recently purchase an RB50 setup with 1 satelite. Quite honestly, I’m less than impressed. I’ve had more dropped connections and resets in the last week than 3 years with my nighthawk. Im hopeful to get some support from NETGEAR here, as I want to believe in the promise of Orbi (plus, I want to avoid running Cat6 in winter)!
On my Network, I have a Chromecast ultra that cannot seem to negotiate properly with Orbi to connect to the 5GHz band. It ALWAYS sticks to the 2.4GHz. Any ideas here? This is also happening to my 1st gen Chromecast. These are located about 10ft through a wall from the main Orbi router (not satellite) so signal is strong. Any help would be VERY appreciated so I don’t have to return my Orbi system and pick up Eero.
- DarrenMSr. NETGEAR Moderator
What firmware version are you on? Have you enabled beamforming and MUMIMO?
DarrenM
- FlausfsuTutor
Thanks for the reponse, Darren!!
1) V2.0.0.74 (tried to update FW, but was not available when I searched via GUI, skeptical due to multiple posts about increased issues)
2) Yes, both are enabled
* I've also disabled Daisy-Chain Topology since I only have 1 satelitte.
In doing some more experimentation today (because signal dropped 4x before 2pm today), I used a wifi analyzer app on my laptop to see the local channel congestion. While I do live a pretty good distance from my neighbors, I can register signal from about 3 other wifi networks. I also noticied that the 2 chromecasts I have were broadcasting 2.4GHz wifi networks on the same channel as the Orbi 2.4GHz network. I reallocated the 2.4GHz Orbi band to an uncongested channel, and will see how that affects performance with signal drops.
Despite doing so, my Chromecasts still only connect to the 2.4GHz despite very good 5GHz signal from the Orbi in those locations.
- godspeedApprentice
FYI, I don't think Gen 1 Chromecast supports the 5 ghz band. 2nd Gen and Ultra should though.
