ArcherDJ
Apr 09, 2021Guide
Circle BROKEN after latest Firmware update
NETGEAR STAFF PLEASE HELP!!!! Since installing the latest update to version 2.6.2.104, my family started complaining that they had access to the internet. I quickly noticed that this was only af...
DBVicAU
Apr 09, 2021Tutor
Hi. What exactly did you do? I have the same issue - but as far as I can see, the firmware is fine.
Did you download the firmware and do the manual update?
Thanks
DB
ArcherDJ
Apr 10, 2021Guide
Yes, downloaded from website, logged into orbi directly from laptop (see manual) then reinstalled the firmware to the main hub. rebooted and then tried to turn circle back on. Which it did. Then tried opening circle app on phone and everything was back to normal... Good luck
- FURRYe38Apr 10, 2021Guru - Experienced User
What version did you manually download and install?
ArcherDJ wrote:
Yes, downloaded from website, logged into orbi directly from laptop (see manual) then reinstalled the firmware to the main hub. rebooted and then tried to turn circle back on. Which it did. Then tried opening circle app on phone and everything was back to normal... Good luck- ArcherDJApr 10, 2021GuideSame one 2.6.2.104. just reinstalled it over the top
- DBVicAUApr 10, 2021Tutor
Thank you!
