mcphael
Sep 16, 2018Aspirant
Circle Firmware Outdated and won’t update
I just installed the Netgear RBR50 Orbi and attempted to set up circle. I received a message that the firmware needed an update. I was prompted for my user name and password which kicked off the updat...
Sep 16, 2018Guru - Experienced User
What FW is currently loaded?
Manually download the FW update file from NG support site and then apply them with a wire connected PC. Update the satelite first then the router.
- mcphaelSep 16, 2018AspirantCurrently firmware 2.0.1.4 is loaded on the Orbi.
- FURRYe38Sep 16, 2018Guru - Experienced User
You need to load v2.1.4.16 to the satellite then router lastly.
Download the files from NG support site for your model Orbi:
https://www.netgear.com/support/
- rahulnSep 16, 2018Aspirant
Hi,
I'm also getting the same error. I'm running v2.1.4.16 on both router and satellite for RB50 and RBS50. Anyother fixes?
Thanks
-Rahul.
