newbietj
Mar 15, 2018Aspirant
Circle Firmware Update Error on Orbi RBK50
I just finished setting up the Orbi system and updating firmware. I am attempting to set up Circle. The first screen is about making sure you are connected to WiFi on your netgear router before you...
slbunge
Mar 18, 2018Aspirant
I’m having the same issues. Updated to the most current firmware via the Orbi app and the Circle app won’t recognize. Please help.
- StarbuckyMar 18, 2018Apprentice
You have to manually download and install firmware 2.1.2.18 for the RBR50 and RBS50. The 2.0.x firmware doesn't support Circle or wired backhaul. The autoupdate is disabled once you're on 2.1.2.18.
- NCHunterMar 18, 2018Aspirant
Thank you! This worked for me.
- markdixon12Mar 19, 2018Aspirant
Will this solution work for both Mac and PC? When I called customer support they wanted be to manually download the same version I currently had, not the 2.1.2.18. I didn't have time to complete the call, but was curious.
- StarbuckyMar 19, 2018Apprentice
Yes it's independednt of operating system. It essentially re-routes requests for any "managed" device.
I don't see why they would say to load the current stable firmware if you want to use Circle, to my knowledge only the 2.1.x fimware versions support Circle.
