dbrown440
Feb 05, 2019Aspirant
Circle goes offline
Every day it seems now, i get a notification from circle that says it is offline. but internet is still connected and i can even remotely access my router.
DexterJB
Feb 05, 2019NETGEAR Moderator
Hi dbrown440,
Welcome to the community!
1. What is the firmware version of the Orbi?
2. Does it stay offline for a long period?
3. To confirm, once you are notified that it is offline, are you unable to make changes on the settings via the app?
4. Are you notified that it is offline while you are within your network/at home?
Dexter
Community Team
dbrown440
2.2.1.210
It will pop up and say it’s offline and I would get a notification from anywhere an hour too a couple days before it says it’s back online
I am able to load up circle and select stuff but it doesn’t seem to effect anything
Yes at times I am and I still have full internet connection.
2.2.1.210
- FURRYe38Feb 06, 2019Guru - Experienced User
You might ask for a Beta FW to see if this help correct what your seeing. There is a new beta avialble from what I hear:
Ask ChristineT abouit it.
2.2.1.210
Yes at times I am and I still have full internet connection. - ekhalilFeb 06, 2019Master
2.2.1.210
Yes at times I am and I still have full internet connection.Can you please check check if you have double NAT as follows:
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8 (traceroute to Google’s DNS server)
If you see two private IP addresses listed in the first two hops then you have double NAT. If you see only one private address and the second hop shows a public address, then you’re all good. :)
