Riehmc
Feb 14, 2021Aspirant
Circle setup loop stuck at password
Can't get Circle app to connect to new system. It says compatible when when creds are entered I get "could not connect". I already reset the orbi twice, and even tried performing circle setup ...
Riehmc
I bought the system used and haven’t been able to register it thanks to the outstanding support team that says the last owner needs to email them? The firmware is 2.7.2.104
vajim
Feb 14, 2021Master
you may want to try and contact one of the forum moderators here (@olympos1625)
as far as the 2.7.2.104 firmware...do a search in here. I believe others have reported the same problem. You may have to try a factory reset to see if that gets you back to a stable version.
