AKB8A
Mar 05, 2018Aspirant
Circle unmanaged filtering not working
I’ve spent hours on the phone with both Netgear and Circle support and have been left with an unresolved issue that I’m hoping either someone else has encountered, or better yet, has a solution. One ...
vcdx71
Mar 06, 2018Star
I've been a long time circle customer, had the standalone device before it was integrated into Orbi. I'm having the same issue and have an open ticket with Circle as I refuse to deal with Netgear support. They are aware of the issue, and I was told a fix would be coming shortly. My ticket number is 53828 if you want to have whoever you worked with reference it.
- AKB8AMar 06, 2018Aspirant
Wow. Thanks for that information. I searched everywhere for some report of this issue, and was told (at least by Netgear) that they had never had anyone report this. I was convinced I had some problem with my setup. I was patched into a call with an Circle tech support person who wasn’t able to figure it out either. I initially sent an email to circle support who sent me right back to Netgear, but I think I’m going to try again. It helps knowing I’m not imagining things.
vcdx71wrote:I've been a long time circle customer, had the standalone device before it was integrated into Orbi. I'm having the same issue and have an open ticket with Circle as I refuse to deal with Netgear support. They are aware of the issue, and I was told a fix would be coming shortly. My ticket number is 53828 if you want to have whoever you worked with reference it.
- sparky87Jul 29, 2018Aspirant
Has any progress been made on this issue? My tablet uses a VPN to connect to work and even when set as an unmanged device cannot make it through. If I set my cellphone to a hotspot, I can get through with it, but not on my faster home network. This is important as I am the designated support for a few programs at work and sometimes need to have access from home. My kids are at an age where circle is proving to be the best deterrent when I can't be available to monitor them. (And they are quickly learning how to circumvent most filtering options.)
- DarrenMAug 01, 2018Sr. NETGEAR Moderator
If you are having issues with circle features on orbi PM me and I will get you in contact with support to work on these issues.
DarrenM
