jr2021
Nov 24, 2021Aspirant
CISCO Set top Box/DVR freezes after 9 seconds when using ORBI RBR750
I am trying to set up my ORBI RBR750, and have an odd problem. The internet connection and wireless is working fine. But, I have a CISCO ISB7150 set top box that is plugged into one of the LAN con...
jr2021
Nov 28, 2021Aspirant
Crimpon: Thanks, I looked at the VLAN/bridge settings that you pointed me to.
I enabled the VLAN/bridge "by bridge group", and enabled ports 1 and 2 on the Orbi router. I plugged my Set top box into Port 1, and the DVR wireless access point into port 2, and the TV works for both the main and remote DVR/TV.
As I understand the (vague) documentation, the Set top box is now bypassing the router's NAT. Hopefully this is also isolated from the other devices on my network, so it won't be a vulnerability.
But, this only works with wired ports, and this prevents me from doing one of the things I'd hope to do with the upgrade to the Orbi, which is to move the DVR wireless access point to the Orbi sattelite to get it closer to my remote DVR/TV. I see the option for setting up the VLAN/Bridge by "VLAN tag group", but I am having trouble figuring out how to add a wireless node to the group. Again, the documentation is not great.
So, for now, this is a partially solved problem. Thanks for your help.
jr2021
Update: it worked for a while, but upon a reboot, the Orbi would not connect to the Modem and external internet. When I disabled the VLAN/Bridge, it reconnects to the Internet. But I lose the TV connection again. Sigh.
Looks like the Orbi is just not compatible for some reason.
