btmi
Dec 27, 2019Aspirant
Cisco SPA112 (ATA Voip) and Orbi are not friends
Everything was working OK with using Orbi in AP mode, but now that the VLAN ID bug is fixed I can use the Orbi router directly, everything worked EXCEPT an ATA SIP box by Cisco (SPA112). Nothing ca...
- Feb 22, 2020
I did get it working everntually, but you MUST disable SIP ALG (on the WAN page of the advanced settings). I also removed the NAT filtering.
Don't forget to reboot your Orbi at the end, because the changes will not be applied until you do.
Jan 02, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance or just modem only?
Something to ask Cisco about to see if they have any help and information regarding this as well...
btmi
Jan 02, 2020Aspirant
I have V2.5.1.8 installed on the router.
The Orbi router is connected directly to the NBN FTTC modem (manufactured by Netcomm).
I have tried a different SIP box manufactured by SIPURA with the same results, but a software-based SIP program on my Android phone can connect when connected to WiFi without any problems. I am pretty sure the SIP packets are being blocked somewhere, but there is no mention of it in the logs. I think I will have to go back to a different router and just use the Orbi in AP mode which is disappointing.
