btmi
Dec 27, 2019Aspirant
Cisco SPA112 (ATA Voip) and Orbi are not friends
Everything was working OK with using Orbi in AP mode, but now that the VLAN ID bug is fixed I can use the Orbi router directly, everything worked EXCEPT an ATA SIP box by Cisco (SPA112). Nothing ca...
- Feb 22, 2020
I did get it working everntually, but you MUST disable SIP ALG (on the WAN page of the advanced settings). I also removed the NAT filtering.
Don't forget to reboot your Orbi at the end, because the changes will not be applied until you do.
UeO
Feb 18, 2020Tutor
Sorry to react so late. Perhaps too late.
Having had similar problems a Sipura ATA, I have given it a fixed IP adress and SIP ALG off.
The ATA is connected to LAN-1 of the RBR50 (router).
Connected to the satellite LAN wasn't succesful
