btmi
Dec 28, 2019Aspirant
Cisco SPA112 (ATA Voip) and Orbi are not friends
Everything was working OK with using Orbi in AP mode, but now that the VLAN ID bug is fixed I can use the Orbi router directly, everything worked EXCEPT an ATA SIP box by Cisco (SPA112). Nothing ca...
- Feb 23, 2020
I did get it working everntually, but you MUST disable SIP ALG (on the WAN page of the advanced settings). I also removed the NAT filtering.
Don't forget to reboot your Orbi at the end, because the changes will not be applied until you do.
UeO
Feb 19, 2020Tutor
Forgot to add: NO Armor and NO Circle !!
- btmiFeb 23, 2020Aspirant
- FURRYe38Feb 24, 2020Guru - Experienced User
Thanks for letting us know how you got it working. Please mark your thread as solved so others will know.
Enjoy.
btmi wrote:I did get it working everntually, but you MUST disable SIP ALG (on the WAN page of the advanced settings). I also removed the NAT filtering.
