Fairorth
Jan 10, 2020Aspirant
Cisco SPA525G IP Phone
Hello, Just got my new Orbi system set up and running and results are fantastic so far. I have the Orbi router and 1 satellite. I have many devices connected, both to the 2.4GHz band and the 5GHz...
CrimpOn
Jan 10, 2020Guru - Experienced User
Wow. What a User Guide!
I am guessing that you connected the phone with ethernet first just to verify that it works and update firmware if there is new firmware. Have you tried the WPS connection?
Fairorth
Thank you CrimpOn!
Not sure if my note qualified as a User Guide but I appreciate the thought no matter what!!
No, I actually didn't connect it directly. I had the phone working for a long time over my existing WiFi, but yesterday I installed the Orbi. I used to have an Arris 1602 cable modem and then a WiFi router provided by Spectrum. I picked up the Orbi, and ditched the Spectrum WiFi, connecting my Orbi router to the Arris. I am using it in router mode but not really doing anything special with Orbi as a router. I wonder if AP mode might be a solution?
No, I didn't try WPS either! Honestly, I didn't realize the Orbi had that feature. I configured the SSID and profile manually on the phone and attempted to connect to it, but the connection (authentication?) failed.
Thanks again for the reply!
Marc
- CrimpOnJan 10, 2020Guru - Experienced User
Every time I replace a WiFi router, I use the exact same SSID and password on the new one, so that my devices do not have to be reconfigured. Did you elect to reconfigure everything?
