Fairorth
Jan 10, 2020Aspirant
Cisco SPA525G IP Phone
Hello, Just got my new Orbi system set up and running and results are fantastic so far. I have the Orbi router and 1 satellite. I have many devices connected, both to the 2.4GHz band and the 5GHz...
CrimpOn
Jan 10, 2020Guru - Experienced User
Every time I replace a WiFi router, I use the exact same SSID and password on the new one, so that my devices do not have to be reconfigured. Did you elect to reconfigure everything?
Fairorth
Yes, sadly(?) I did. I renamed my SSID ORBIxxx without really thinking through the consequences ....
- CrimpOnJan 10, 2020Guru - Experienced User
If the WPS button doesn't work, maybe there is something in the "real" User Guide that will help:
Fairorth wrote:Yes, sadly(?) I did. I renamed my SSID ORBIxxx without really thinking through the consequences ....
Is that ORBI and three digits? Some people on the forum have confused the "I" in "ORBI" with a numeral "1". My (old) Orbi had a defalt of ORBI+two digits, not three. I believe they thought the odds of there being 99 Orbi's close enough to interfere was close to zero. With three digit numbers, it would be very long odds indeed.
