GPSK
Sep 13, 2018Follower
Clear DHCP lease for inactive clients
How can I Clear DHCP lease for inactive clients in Netgear Orbi RBR50 router? I updated my systems and want to assign old IPs but router is assigning new one only.
1 Reply
If you updated FW, I would do a factory reset on the router and set up from scratch. Then go in and set up IP address reservations for each device. Save settings and after you check to ensure all is working, save off a save router config to file for safe keeping.
