karloy007
Dec 23, 2017Aspirant
Client Isolation between Router and Satellites?
I upgraded to an Orbi Router (RBR50) and two Orbi Satellites (RBS50) to get coverage for my house, and the backchannel speed is as great as advertised. That said, I am running into odd network issues...
DarrenM
Dec 27, 2017Sr. NETGEAR Moderator
Yea I would try setting up static routes and see if that works.
DarrenM
- karloy007Dec 27, 2017Aspirant
I addressed the issue by setting it to AP, and use the FIOS Quantum Gateway routing functionality. Another issue I discovered was that UPnP didn't work correctly. Before, I found some instructions how to set the FIOS Quantum Gateway into bridge mode and use Orbi as router, but apparently it didn't work properly. Setting Orbi to AP addressed it.
- Greystorm64Dec 27, 2017Apprentice
But, why would you do that? I had the Quantum router, but I wanted to get rid of the router, so I replaced it with the Orbi for performance improvement.
Putting the Orbi into AP mode and connected to the internet through the router I wanted to replace would be defeating the purpose of having the Orbi Mesh-Network in the first place.
Wouldn't it? I might be missing something as to why anyone would do that.
I would appreciate understanding your reasoning. Might help me understand things better.
I can't get rid of my FIOS modem/router, since my connection from the in-house box is coax, not ethernet . Once you have ethernet and only internet service, i think you can remove the FIOS modem/router.
AP for FIOS router seems to be officialy recommended/supported, I don't see any performance downgrade (actually an upgrade, since I had issues with lost connections before).
https://kb.netgear.com/31100/How-do-I-set-up-my-Orbi-system-to-work-with-Fios
