karloy007
Dec 23, 2017Aspirant
Client Isolation between Router and Satellites?
I upgraded to an Orbi Router (RBR50) and two Orbi Satellites (RBS50) to get coverage for my house, and the backchannel speed is as great as advertised. That said, I am running into odd network issues...
Greystorm64
Dec 28, 2017Apprentice
OK, I think I can understand that. I purchased the 7000 sqft offering, came with an RBR50,RBS50 and RBS40.
The 40 is dead anding being RMA'd.
Would I set up 3 AP's? would they all still be the same wifi SSID? Would devices move from AP to AP as they moved away from one AP's zone into another?
Would I hard wire the OBR50 to my Quantum Gateway (after turnning the Orbi into a Bridge? I assume, I would disable the wifi on the Quantum and only keep the ORBI SSID visible?
OK, all well and good, my Quantum router seemed to always give my hardwired devices full bandwidth of 150MB all the time. The Orbi was to get rid of dead spots and improve the performance of the wifi (as the Quantum Wifi side had some real performance issues.
BUT, that wont stop my issue of devices dropping from the Orbi's randomly. It wont stop all the devices to connect to the RBR even through an RBS is much closer. It wont stop devices from bouncing between 2.4 and 5ghz networks at random times.
It wont solve the issue of the device list on the RBS's are allways empty, even when I have a device hard wired to one of them (and the device works fine and has full access to the internet).
It wont solve the issue of the RBR device list not showing all the devices that are on the network. And I have verified by checking for the precnesne of abcense of MAC address of devices that were actually accing the internet or streaming from the internet. the device showed up no where in any device list... and it would show up for hours, even then. It was random. Some would finally show, some would never show, and others would drop from the list, but still seem connected to the internet.
SO, I could use the FiOS router, set up 3 AP's with my ORBI's and still have all these random issues.
I am close to packing it all away and sending it back.
Get me a NightHawk router with an AP or 2 to ensure I cover the access points. I just didn't want the family and guests to have to figure out which AP or Router SSID they should connect to.
st_shaw
Dec 28, 2017Master
When you change Orbi to AP mode, the entire system becomes a network of access points with one SSID.
Yes, you would hardwire the Orbi RBR50 Yellow Internet port to a LAN port on your existing router. Yes, you would disable WiFi on your existing gateway.
There is a bug in the current Orbi firmware, where the attached devices list incorrectly shows where devices are attached. Most devices show as connected to the RBR. So, you believe all your devices are attached to your router, but that is almost certainly NOT the case. To be certain which Orbi your devices are connecting to, you would need to check on your devices and see what MAC address they are connecting to for WiFi. If your devices are giving you good throughput, then you don't really need to worry too much about where they are attached.
When Orbi is in AP mode, you can refer to your existing router to get a list of devices on the network. I you have manually configured any devices with a static IP, these devices may not appear in any router device list. Manually configured client devices could also cause IP conflicts which could lead to devices dropping off the network.
Many devices (laptops, cameras, Macs) simply are not designed to roam, and will not roam, so you will need to reboot them or cycle their WiFi off/on after you move the device, or after you reboot or power-cycle Orbi. Note that when Orbi reboots, the RBR will come up first and many of these "sticky" devices will attach to the RBR and stay there.
I don't know what's causing your devices to drop randomly. I have run Orbi in access point mode for a year now and have never encountered this issue, except when I had the satellite too far from the router, or when I had other wireless devices too close to Orbi or improperly configured. Usually these types of issues are caused by RF interference from other devices (wireless speakers, nearby WiFi devices, Bluetooth, etc.) or are due to issues with devices from different manufacturers not working well together. Moving the satellites closer to the RBR, and making sure you separate the Orbis from any other wireless devices might resolve the dropouts,
- Greystorm64Dec 28, 2017Apprentice
Not so sure.... I agree, there are some connected to the RBS... because if you look at the Device List in the RBR, the very far right column labled "Connected to Orbi" shows 2 devices connected to Orbi Satellite-1, while ever other device shows connected to the Orbi Router.
So, while I know that an empty list on the RBS doesn't indicate no devices are connected to it, the Router itself only shows 2 devices coming from the Satellite and the rest direct to the Router. It never changes either, no matter where I go in the house or how long I stay there.
Its always the same 2 devices list as Orib Satellite-1 that were first to connect yesterday morning when I shut everything down and brought it all back up 1 at a time.. all 40 devices.
No other device ever shows listed on Satellite-1. Also, I can sit with my phone with an app that measures single strength RIGHT next to the RBS.. it should show 100%... but it shows 45%, as its connecting back to the router which is upstairs and a way from me.
In the Orbi phone app, you can view signal strength. of all the devices that are in range of the RBS (and out of range of the RBR - or at least futher away) all show low signial strength... no matter how close they are to the RBS, which if they were connected to the RBS, the signal strength would be a lot higher that ~40%.. since I have 12 devices withing 8-10 feet of the RBS and NONE of them show over 50%.
So, this single SSID for multiple AP's just doesn't seem to be working. Since, no devices will connect to the RBS except for the very first 2 I turned on yesterday. and one of those 2 is hard wired.
- aazDec 28, 2017Virtuoso
Yes, that list on the router is broken as well. I am sure some of my devices are roaming and appear on the router list as connected exclusively to the router.
- st_shawDec 28, 2017Master
I would agree with your assessment of the ~40% signal strength indicating you are not connected to the nearest Orbi RBS. Turn your WFi off then on again on you phone and check the strength again. If your phone does not connect to the nearest satellite, then there could be something wrong with your satellite.
In any case, maybe what I wrote wasn't clear, so let me say it another way... There is a bug in the Orbi firmware that causes the attached devices list on the router to show devices that are truly connected to the SATELLITE to appear in the list as connected to the ROUTER. I am saying this could be the reason why you believe almost all your devices are connected to your router. As I write this, my Macbook is connected to the satellite, but it appears in the Orbi list as connected to the Router. The right hand column you are referring to is inaccurate. You cannot rely on it.
Here is one way you can tell for sure where a device is connected. Run a WiFi scanning application and record the mac addresses of your Orbi and satellites (there are two mac addresses per Orbi device--one for 2.4 and one for 5 Ghz), then check on your devices' network properties which mac address they are connected to. On OSX you option-click the WiFi icon to see the mac address of the associated WiFi access point. I'm not sure how to do this on Windows.
- Greystorm64Jan 02, 2018Apprentice
Thanks for the recommendations. I did understand your explanation regarding how devices are showing up in the RBR device list, even though they are actually connected to the satallite.
The device list in the RBR does actually show if its connected to the router or a satallite in the last colum.
Unfortunatly, it only shows 2 devices and never another, and those were the first 2 to connect when I reset my entire network.
No new devices show up as connected to a satalite.
I have been testing, everything still only connectst to the RBR. very very annoying. I have a a case open with Netgear, but they don't seem to be in a hurry to fix it.
