winstonw
Feb 03, 2022Aspirant
Close a range of ports
I have beaten my brains out trying to find a solution to my open ports. I can find everything I want to know about opening ports but NOTHING about how to delete them. I have a huge range of ports tha...
Feb 03, 2022Guru - Experienced User
If you have uPnP enabled you can disable this.
I would check to see what is uses those ports first.
- winstonwFeb 06, 2022Aspirant
Thanks for the prompt reply. I have a few devices that use UPNP but this range that I accidently opened needs to be closed. If I disable UPNP, I'm afraid that it might crash my NAS security which was set up using UPNP. I feel like I accidently opened a snakes nest!
