sparh
Jan 12, 2022Tutor
Cloudflare captcha required when navigating the web using ORBI WiFi network
Hello, Here is my product : https://www.netgear.com/ch-fr/home/wifi/mesh/rbk853/ Since a few days when I am on my ORBI Wifi network most websites require me cloudflare captcha before accessing them...
- Jan 16, 2022Hello
I finally switched to ap mode and things are getting better
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
Thanks for your help
CrimpOn
Jan 12, 2022Guru - Experienced User
(I keep forgetting about Armor) On the Orbi app, what does the Security panel say about Armor?
Mine has the words "Protect with Armor Now". When I click on the Security panel, it opens a page offering the free trial.
I would not be surprised if Armor has gone into some strange "Twilight Zone" that can be cured only by resetting the router.
sparh
Jan 12, 2022Tutor
Mine is saying « expired renew Armor now »
If I click I am redirected to a shop page to buy Armor https://store.bitdefender.com/order/checkout.php?PRODS=34579834&QTY=1&CART=2&CLEAN_CART=ALL&SHORT_FORM=1&COUPON=Netgear-Orbi-44-99USD&CID=ipm%7Cnetgear%7Capp%7C35_off
- CrimpOnJan 12, 2022Guru - Experienced User
I would be tempted to do a "Quick Factory Reset" on the router. i.e.
- Save a copy of the configuration. (On the Orbi web interface, Advanced Tab, Administration menu, Backup Settings.
- Do the paperclip routine: https://www.youtube.com/watch?v=cMw4ePACgc4
- Begin the setup using a web browser (not the 'app')
- Do not change the WiFi SSID/password. (This keeps devices from connecting and possibly getting an IP address that will conflict with any settings you have made.)
- Proceed until you come to the step that asks if you want to
* Continue with configuration, or
* Load a saved configuration - Select "Load a saved configuration" and do so.
- The router will reboot and all of the previous settings will be restored. (The LAN setup table, the SSID/password, everything.)
This process takes under 15 minutes. (With all the changes I have made, a manual configuration takes over two hours.)
Might result in no improvement, but the investment of time is minimal.
- sparhJan 16, 2022TutorHello
