lineaux
Oct 11, 2020Aspirant
CM1100 and Orbi RBR50 - recommended settings
Hello, I have an existing currently working almost flawlessly (on AP mode) with an att uverse gateway. A very straightforward setup. I will be moving to xfinity internet soon and already purch...
- Oct 12, 2020
A power OFF of the modem for 1 minute then back ON maybe needed to effect this.
Oct 11, 2020Guru - Experienced User
Yes the RBR needs to revert back to router mode if you connect it to the CM1100.
Disable LAG on the CM modem and be sure to connecdt to WAN #1 port on the CM modem with the RBR.
Be sure to power OFF the RBR after setting router mode. THen connect to the CM modem. Power the modem ON first and besure it's activated by the ISP correctly. After the modem is online fully, then power ON the RBR. It should get internet services with out any other changes.
This would be all thats needed.
- lineauxOct 11, 2020Aspirant
Thanks for the information. I have noted the LAG setting on the CM.
I wanted to make sure that aside from changing the RBR settings from AP to Router mode, no other changes are needed.
Also, I just remembered that I need to ask the tech about the CM FW update. I assume that the CM only have the 'default' FW version loaded (V2.01.02) out-of-the-box. I wonder if the comcast-deployed FW (V6.01.07) is automatically uploaded during activation.
- FURRYe38Oct 11, 2020Guru - Experienced User
ISPs are reqponsible for FW updates on cable modems. There is no user appliable FW updates for modems. Some ISP may not push FW udpates to user owned modem. Contact the ISP for further information regarding this.
Good Luck.
- quagmire1Oct 12, 2020Luminary
lineaux wrote:I wonder if the comcast-deployed FW (V6.01.07) is automatically uploaded during activation.
Comcast should automatically load the latest firmware onto your modem upon activation.
- FURRYe38Oct 12, 2020Guru - Experienced User
