lineaux
Oct 11, 2020Aspirant
CM1100 and Orbi RBR50 - recommended settings
Hello, I have an existing currently working almost flawlessly (on AP mode) with an att uverse gateway. A very straightforward setup. I will be moving to xfinity internet soon and already purch...
- Oct 12, 2020
A power OFF of the modem for 1 minute then back ON maybe needed to effect this.
lineaux
Thanks for the information. I have noted the LAG setting on the CM.
I wanted to make sure that aside from changing the RBR settings from AP to Router mode, no other changes are needed.
Also, I just remembered that I need to ask the tech about the CM FW update. I assume that the CM only have the 'default' FW version loaded (V2.01.02) out-of-the-box. I wonder if the comcast-deployed FW (V6.01.07) is automatically uploaded during activation.
Oct 11, 2020Guru - Experienced User
ISPs are reqponsible for FW updates on cable modems. There is no user appliable FW updates for modems. Some ISP may not push FW udpates to user owned modem. Contact the ISP for further information regarding this.
Good Luck.
