lineaux
Oct 11, 2020Aspirant
CM1100 and Orbi RBR50 - recommended settings
Hello, I have an existing currently working almost flawlessly (on AP mode) with an att uverse gateway. A very straightforward setup. I will be moving to xfinity internet soon and already purch...
- Oct 12, 2020
A power OFF of the modem for 1 minute then back ON maybe needed to effect this.
quagmire1
Oct 12, 2020Luminary
lineaux wrote:I wonder if the comcast-deployed FW (V6.01.07) is automatically uploaded during activation.
Comcast should automatically load the latest firmware onto your modem upon activation.
Oct 12, 2020Guru - Experienced User
- lineauxOct 15, 2020Aspirant
Update: Xfinity service activation went on smoothly, We run into a small issue when the technician immediately moved the RBR connection from the att gateway to the CM once he determined that CM was working. I had perform a few reboots to get all the equipment sync'ed up and change the RBR setting from AP to Router mode.
Confirmed that the latest Comcast-deployed FW was installed; and, the LAG is disabled
Thanks you for all your input. much appreciated.
- FURRYe38Oct 15, 2020Guru - Experienced User
Enjoy. :smileywink:
